Old 06-05-2017, 06:48 PM   #1
Jason@SportsCar
Originally Posted by MugenRep View Post
-deflating tires to 20psi to decrease diameter lower than the 23.8" diameter, hopefuly closer to 22.4-22.6" to give a bit better gearing
It doesn't work like that. Just because you see the weight of the car squishing the tire does not mean you made it smaller. Centrifugal force is going to pull the tire out to its engineered diameter. The only reason to lower pressures is to try and gain traction on the launch, likely not much of an issue at your power level. If anything you are likely hurting your MPH because you are dragging an under inflated tire all the way down the track. Better option, keep adding air until you cant launch, it will offer less rolling resistance.
Old 06-05-2017, 07:23 PM   #2
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Awesome!!! Thank you! I did not realize that the extra skacj would hurt the traps at the end of the 1/4 mile. Very much appreciated! I'll be maximizing the pressure to the point of loss of traction the next I go in that case.
MugenRep is offline   Reply With Quote
