Old 06-10-2017, 03:03 PM   #1
kwk442
Drives: 2010 Yaris
I just used a small wrench...
kwk442 is offline   Reply With Quote
Old 06-10-2017, 04:12 PM   #2
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
If you broke that 14mm bolt loose with a small wrench the first time you should enter arm wrestling contests. The bolt is on really really tight from the factory. After I broke loose for the 1st time it is easy to loosen as I torque it to the factory spec of 40lbft( for some reason it is on much tighter than 40lbft from factory). Now that it's torqued properly I could probably break it free with my long handle matco 1/4!drive ratchet.
Toolaholic is offline   Reply With Quote
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
