Old 06-11-2017, 06:10 PM   #1
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Yea it is I had to take out the size 10mm slide the bracket for the ac line to the side and was out my alternator light is Ben on for almost a year but the alternator still work
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 06-11-2017, 07:41 PM   #2
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
with my way 10mm ac bolts stay put. And a gearwrench torque wrench fits. The 3:8 to 1/4 adapter with 1/4 drive 14mm socket clear the alternator but still leaves room for ratchet to clear a/c lines. Bolt is so long I might have removed the 10mm bolts. Definitely do not have to remove 10mm bolts to move alternator to remove and tension belt.
Toolaholic is offline   Reply With Quote
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
