Old 06-12-2017, 11:25 AM   #1
soldiersvejk
Drives: 2009 Toyota Yaris Sedan
when screwing into the two holes, make sure that you have released the emergency brake.
I kept the emergency brake applied and the brake shoes were push so tight against the drum, so I one spring actually popped off, and caused small cracks on the backing plate.
Luckily I was able to put the spring back, but I really worried that the spring will come off someday.
soldiersvejk is offline   Reply With Quote
Turn rear brake drums? robkay DIY / Maintenance / Service 10 12-29-2013 09:23 PM
Bent brake drums after installing new rims angrygenerator Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-01-2013 12:09 PM
Rear drums Evangelion335 Performance Modifications 13 12-04-2010 12:44 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
rear drums the same on '01? cali yaris Performance Modifications 7 11-21-2008 10:46 AM
