![]() Drives: Toyota yaris sedan 4 door Join Date: Jun 2017
Does anyone have some idea on my A/C repair?
Hi everyone,
I checked my A/C from a repair store several days ago, and the maintenance guy told me that the hose was unplug by somebody and he did not know why the personal did this. What the maintenance guy recommend is to replug a new hose and replace the condenser, and then do the check to see which part is not working. However, the fees are about 600 bucks so I decide to repair by my own. Does anyone have some experience in checking A/C before? Could you give me some advice (Including which tools I need to check A/C, what procedures for check, what need I pay attention)? Thanks! |
Its either your Discharge Line or Liquid Line. Its hard to tell by looking at these angles, what year and model do you have? Either way, this is something I wouldn't want to mess with given the toxicity of the fumes can kill you if you breath them in. You're missing that line.
#3 | |
you need to find out if compressor is working before spending any amount of dollars...
Definitely looks like you are missing a hose.
Tools that you'll need to start is an a/c manifold gauge set and a vacuum pump. I bought mine for just over $100 on eBay. They're cheap but fine for infrequent use of a shade tree mechanic. Just make sure you have vacuum pump oil for the pump when you get it. I've discharged and refilled my a/c system in my car 3x this way and had no issues. Also checked the pressure/topped up refrigerant in my Vibe to make sure it was all good. You can use the vacuum pump to check if it holds vacuum and if it doesn't than you have a leak. Do this before you refill it. Also if you're refilling your system, a quick tip is to add in a uv dye so if you ever have a leak down the road you'll know exactly where it is and can just buy that part instead of guessing
#7 | |
#8 | |
so here is the second person telling you that a manifold gauge set and a vacuum pump is needed to complete a/c repairs. |
If you wanted to see if the compressor operates, you can jump the relay. That being said, I can't recommend inexperienced guys to be jumping power: Too likely to damage expensive computers.
If you are wanting to get your a/c working, I would suggest replacing the missing suction hose and your dryer, then call a local A/C guy to leak-check and recharge it. I wouldn't be surprised if your compressor was dead from sitting though. |
nope
If you have never done A/C repairs before I would not recommend doing your own repairs unless you have a helper who's done it before. You can only check to see if the clutch engages on/off without the compressor spinning or you'll damage compressor.You really can't check the compressor unless it has Freon/oil in the system or you'll cause damage to the compressor. And you can't just put Freon unless the system is properly flushed and cleaned first. The safety low and high pressure switches are there for a reason. There is a lot of work required in order the get this system back operational. I would recommend taking it to an A/C shop. I just replaced the A/C system myself in my VW new beetle two years ago and it is a lot of work, a lot of steps where things could go wrong and you almost have to start over again. It took me a whole weekend.
| Help: A/C Questions | flamingchicken4 | DIY / Maintenance / Service | 11 | 12-29-2018 12:53 PM |
| Free Service & Repair Manuals for Yaris | freddist | DIY / Maintenance / Service | 0 | 03-29-2017 08:57 AM |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
