Old 06-12-2017, 10:05 PM   #1
casliupeng
Drives: Toyota yaris sedan 4 door
Originally Posted by SirDigby View Post
you need to find out if compressor is working before spending any amount of dollars...
Thanks, how could I check that by myself? Does there need some detect machines? Given my hoses are disconnected, could I turn on A/C to check by my eyes?
casliupeng is offline   Reply With Quote
Old 06-13-2017, 09:14 PM   #2
SirDigby
Drives: 2007 yaris 3 door
it will not turn on because the pressure switch will cut the power. i don't know if it's a NC or NO switch. you'd need to figure out how to by-pass it. or, you might be able to run power directly to compressor. you would need to get a wiring diagram for that. you would want to remove the belt before testing. also, i don't know if you'd need to engage the clutch on the compressor to check operation. it's prob easiest to defeat pressure switch(s) and operate from HVAC controls... a NO switch will work if unplugged. a NC switch will need to be jumpered at the connector. check pressure and suction at inlet/outlet. your manifold gauges will be needed for this...
so here is the second person telling you that a manifold gauge set and a vacuum pump is needed to complete a/c repairs.
Help: A/C Questions flamingchicken4 DIY / Maintenance / Service 11 12-29-2018 12:53 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
