Old 06-13-2017, 12:00 AM   #1
tmontague
tmontague's Avatar
Definitely looks like you are missing a hose.
Tools that you'll need to start is an a/c manifold gauge set and a vacuum pump. I bought mine for just over $100 on eBay. They're cheap but fine for infrequent use of a shade tree mechanic. Just make sure you have vacuum pump oil for the pump when you get it.
I've discharged and refilled my a/c system in my car 3x this way and had no issues. Also checked the pressure/topped up refrigerant in my Vibe to make sure it was all good.
You can use the vacuum pump to check if it holds vacuum and if it doesn't than you have a leak. Do this before you refill it. Also if you're refilling your system, a quick tip is to add in a uv dye so if you ever have a leak down the road you'll know exactly where it is and can just buy that part instead of guessing
Old 06-13-2017, 12:25 AM   #2
casliupeng
Drives: Toyota yaris sedan 4 door
Many thanks for your detailed response:)
casliupeng is offline   Reply With Quote
Help: A/C Questions flamingchicken4 DIY / Maintenance / Service 11 12-29-2018 12:53 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
