#1 | |
Just a Gaijin
I've done a before and after test with new tires, lightweight alloys and air intake. The car was stock before. Before with winter tires and stock air intake the best i could do was 11.1 sec After with new sticky summer tires and aftermarket air intake the best i could do was 11.3 sec. So after i did the mods my 0-62 times were worse than before. So i guess my winter tires stick well enough to put the power down and it all comes down to the launch and your shifting. You can scrape off some time with good shifting. But with a bad launch my times are always in the 12-13 sec range. My engine is the 1.3l 2SZ-FE Last edited by DiCaprio; 06-16-2017 at 07:40 AM. |
#2 | |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
The biggest difference that comes into play between your time and mine is that our engines are different. I have the 1NZ, and even with a wheel/tire setup that is heavier than stock and an axleback I've been able to get a 10 second range 0-60 with everything stock otherwise. Sticky tires can take away performance of a car also. They have a higher rolling resistance, which basically means that you need more energy to move them than a tire with lower rolling resistance tires such as snow tires or energy conserving tires. With the 2SZ being limited on power already as is, sticky tires can negatively impact the performance. Honestly, just by adding an intake and exhaust isn't going to make any car much faster (there are exceptions). It will however make your car louder, and if that is what floats your boat then |
| Simota CF650-6 Air Intake Review | invader166 | Performance Modifications | 16 | 12-21-2015 03:31 PM |
| For Sale: Fujita F5 Cold Air Intake | invader166 | Items for Sale by private party | 2 | 11-21-2015 11:10 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| cold air intake | 400 dollar yaris | Performance Modifications | 10 | 10-02-2012 06:33 PM |
