Old 06-27-2017, 12:50 PM   #1
KTS
KTS's Avatar
Drives: Vitz RS
This is what i did for the rear mount. Cannot complain. There is some vibration but your passengers wouldn't be able to tell. The mount is still good up to this day.
https://r.tapatalk.com/shareLink?url...3&share_type=t
Polyurethane Engine Mount (not 3m)
KTS is offline   Reply With Quote
Old 06-27-2017, 10:22 PM   #2
tmontague
tmontague's Avatar
Did the metal sleeve come with the poly bushing, or did you have to order that separately from red line?
This seems like the best option and something I'll likely do down the road when my poly dogbone gives out
Old 06-27-2017, 11:07 PM   #3
KTS
KTS's Avatar
Drives: Vitz RS
The prothane mount was cut to size. I don't think that they replaced the metal sleeve when they removed the old rubber. Most shops locally will burn out the old rubber with a blow torch.
Sent from my SM-G920V using Tapatalk
Old 06-27-2017, 11:25 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I cut chunks of silicone couplers (for intake connections, etc) & jammed them into the voids of the torque mount & the trans mount.
for the fluid motor mount, I gutted it and filled the top and bottom with 60a urethane
idle is noticeable but otherwise its not bad at all
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Japanese engine into French Yaris 1.0 2002 Jamie101 DIY / Maintenance / Service 5 02-12-2018 10:41 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
