![]() ![]() Drives: 2012 Toyota Yaris Hatchback Join Date: Feb 2017
Strategies for Reducing Engine Play
Hey All,
It seems like the motor mounts in my Yaris are made of silly putty. I was wondering if anyone else has experienced this, and if so, what modifications have you made to reduce the play without adding a ton of vibration? In the past I have filled motor mounts with window weld or similar, and added inserts. I imagine that would work just fine here as well, but I would like some input on which mounts make the biggest difference. I don't want to fill all of them on this car, and end up with tons of vibration, but I would like to be able to shift quickly without the engine rocking around like freebird is playing. I have also heard there is additional/better mounts off higher trim level/TRD Yaris I can get and add, but I can't find any concrete info on it. Thank you! Matt |
I bought 80A polyurethane from online and properly filled all my mounts (except for the passenger side fluid mount). I do have more nvh but I'm happy with it and it was easy to do. Just take a while to cure so your best bet is to buy new mounts and fill those then install.
http://www.energysuspensionparts.com/diymmi
What mounts are on a Yaris stock? I can't seem to find out if there is a dogbone on base model Yaris, or if that is only at the higher trim level.
If there is a dog bone, I would like to try filling that first. |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
This is what i did for the rear mount. Cannot complain. There is some vibration but your passengers wouldn't be able to tell. The mount is still good up to this day.
https://r.tapatalk.com/shareLink?url...3&share_type=t Polyurethane Engine Mount (not 3m) Last edited by KTS; 06-27-2017 at 01:18 PM. |
Awesome! I imagine the 2012 has a similar rear mount? That would work perfect for my needs.
Thank you!! |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Other option is to take the stock bushing out of the dogbone and press it back in rotated 90°. Costs you nothing and you can always go back to the way it was if it shakes too much.
FYI the Yaris is a pretty rough little engine at idle. You will get a decent amount of vibration with stiffer mounts. |
#7 | |
This seems like the best option and something I'll likely do down the road when my poly dogbone gives out
#8 | |
Sent from my SM-G920V using Tapatalk |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I cut chunks of silicone couplers (for intake connections, etc) & jammed them into the voids of the torque mount & the trans mount.
for the fluid motor mount, I gutted it and filled the top and bottom with 60a urethane idle is noticeable but otherwise its not bad at all
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
![]() Drives: Man Join Date: Jul 2017
Updated:
For those who have more experience with porting, do you have any suggestions before I put this thing back together? |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
I have the TRD engine and trans mount. I know Beatrush sells an upgraded dog bone mount
"It hurts more when its wet" |
| Japanese engine into French Yaris 1.0 2002 | Jamie101 | DIY / Maintenance / Service | 5 | 02-12-2018 10:41 AM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
