Old 07-04-2017, 06:36 AM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Just ordered OBX spacer for Scion and OBX header for Yaris. Looking at OBX site, the spacer is readily available and on site, whereas the header is done, no longer available on site. I bought from Amazon, and when buying two items from OBX thru Amazon, get 12% off. Initial pricing was 74.99 and 199.99 for the header, with 12% off each, their math came to 33 bucks off. Sweet. I will install and report back.
To note, I put a TRD CAT back (rear muffler, really) and did see some mild but worthwhile gains.
Here is hoping for more of the same.
I will be getting new gaskets for each needed that doesn't come with set already.
Contemplating TC TB as well as pulleys, but will see what these two items net me.
Old 07-06-2017, 09:43 PM   #2
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by JimKellyfan View Post
Just ordered OBX spacer for Scion and OBX header for Yaris. .
you should have bought my ported manifold and custom spacer...
Old 07-10-2017, 10:13 AM   #3
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
How much
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
