Old 07-16-2017, 04:14 PM   #1
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Your long term fuel trim number of -14.8 is way, way off. Far enough in the USA that it would trigger a check engine light. It's posible to be an air filter but it would have to be the most plugged air filter I have ever seen in my life! I live in Seattle WA so the air is crystal clear (because it rains, and rains, and rains and rains) I have 100k miles on my air filter and it flows fine. Do you live in a dusty or dirty environment?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Old 05-31-2018, 04:12 AM   #2
ojeysky
Drives: Sedan Yaris 2010
Hello,
I am experiencing exactly the above and my fuel consumption has been quite bad as i now do about 200miles on full tank! I am attaching log of my bluedriver scan result, will appreciate pointers on what could be the cause of this. I have checked for vacuum leaks but found none.
Thanks
ojeysky is offline   Reply With Quote
Old 06-16-2018, 02:20 AM   #3
ojeysky
Any response, am still get a bad milage. Vehicle is 2010 Yaris sedan AT with post cat 02 sensor recently changed.
