Old 07-26-2017, 09:38 AM   #1
Rigaud
Drives: 2009 Yaris
32f - 28r
205/45R16
1ZZ throttle body and intake, header, 2-1/4" freeflow ss exhaust, lowered and TRD sway bar.
@ 95-100kph I do 5.4 to 5.6L/100km Hard driving.......7.4L/100km
Fuel economy is all about how you drive.
My 2009 2dr hatch swayed....floated on the highway before the sway bar was installed. It holds straight like on rails since.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-26-2017, 10:30 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
My '07 suffered from terrible highway wander and float. I installed a rear TRD anti-sway bar which indeed helped with stability at cruise to some degree, but did not eliminate this problem. (Of course, handling in corners was much improved).
I experimented with multiple tyre tread patterns and tyre pressures with and without the anti-sway bar. I discovered that highway wander could be completely eliminated with the correct tyre; tread pattern is all important on the Yaris.
I learned to be very selective choosing the right tyres for my '07 and now my '14. I've always used 205/50/16's with 32 psi front and 29 psi rear. I'm on stock suspension, and I don't use the rear anti-sway bar. I can drive the car at 90MPH with no wander and no float.
Old 07-26-2017, 04:07 PM   #3
Pinchlite
Drives: 2007 yaris HB
32f - 28r
205/45R16
How does a rear sway bar effect the front when driving in a straight line?
Pinchlite is offline   Reply With Quote
Old 07-26-2017, 06:01 PM   #4
Rigaud
Drives: 2009 Yaris
Google it or search this site!
Old 07-26-2017, 08:59 PM   #5
SirDigby
Drives: 2007 yaris 3 door
it does not have any effect unless you have strong cross wind. it's for cornering stability.
not sticky tires, eh? oh, you must have got the pilot sport A/S 3+
you're right. the UTQG is 500 AA A
my mistake...
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
