![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
You obliviously have an exhaust leak at the front. The most common culprits would be the exhaust manifold gasket (#2), a crack in the exhaust manifold (#1), the manifold to mid pipe gasket (#6), and a hole somewhere in the mid pipe (#5). Take a look under the hood behind the engine to get a look at the exhaust manifold to see if the leak is there or further down the system. The exhaust manifold has a heat shield (#4) which you might want to take off to get a better look. If the leak is in the engine bay those fuses will eventually get into the cabin so I would get it fixed sooner rather than later. With a very loud exhaust you also run the risk of getting a ticket for that. Here's a diagram of the exhaust system on the 05 Echo HB:
![]() https://parts.charlesglentoyota.com/...M/8326145.html |
#2 | |
![]() Drives: Toyota Echo RS 2005 Join Date: Dec 2016
risk intoxication carbon monoxide or not ? |
| Looking for Echo Borla exhaust | RyanEchoRS | Willing to Buy by private party | 2 | 08-16-2017 07:37 PM |
| Wtb borla exhaust for 2005 echo hatch | Baklarz | Willing to Buy by private party | 1 | 07-08-2013 11:16 AM |
| Micro Image center exhaust... | tooter | Performance Modifications | 64 | 10-14-2012 11:07 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Echo 98-05 Koni Front Yellow Shocks/Struts Pair 04 03 | Fer.pa | Central and South America | 3 | 07-02-2007 03:43 PM |
