VSC and ABS lights on.
Diagnostics showed left front abs sensor fault, but changing it for new one did not help. Signals got thru from ABS "brain" and wiring were OK, but couldnt read the wheel locking. Inside the wheel drum we saw a lot of rust, could this be the cause? Has anyone had this kind of problem?
#2 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
had the exact thing happen on my 09 tacoma.changed the wheel bearing hub assembly.got both lights.changed the sensor,didnt help, traced the harness and bought the lower one.didnt help.swapped the sensor from the rear to the front,didnt help.lights clear at about 28 mph, but come back on at 62 or so.went thru some water one time and it did the same thing, but it cleared the next day.
Took some time, but all OK now.
Took it to dealership and they found broken wire somewhere between abs sensor and enginebay. All good now, though i have some doubts about wire being broken. |
| what winter tires do you use ? | henry33 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 60 | 12-09-2010 10:31 PM |
| 2010 in Canada : ABS and VSC optional??? | pierdeux | New YARIS Purchase Forum | 4 | 03-28-2010 03:23 PM |
| Invasive creature or standard feature? Small cars and VSC, ABS, and traction control | Thirty-Nine | General Yaris / Vitz Discussion | 19 | 08-10-2009 11:29 AM |
