Old 07-31-2017, 04:27 PM   #1
B.B._07
Drives: 07 5dr
Originally Posted by chrisgblues View Post
Does anyone know how much coolant I should buy if I just want to drain and refill the radiator? Also is do I just simply unscrew the drain plug, or is there some trick to getting it off? Thanks!
Total coolant capacity is 4.7/4.8L (AT/MT), however since some coolant will remain in the engine block and heater core a regular 3.78L jug is more than enough. I prefer the concentrate over the premix since you get double the coolant for a few dollars more. Just need to turn the drain petcock at the bottom of the rad.
Old 08-01-2017, 02:22 PM   #2
chrisgblues
Drives: 2007 Toyota Yaris
Thanks!
chrisgblues is offline   Reply With Quote
