Old 08-01-2017, 08:23 PM   #2
B.B._07
Drives: 07 5dr
Short of replacing on with a new door or a used one from a salvage yard, I think you best bet would be to try the zip tie stitch method. You would need to drill a few matching holes on each side of the break and zip tie it back together. It may not look pretty but will be plenty strong. I'd use some small black zip ties to minimize the effect. You could also try the plastic weld method using a soldering iron, but I think that would not be as strong.
Dual 8’’ Cargo Floor Sub Box Build Ataristyle In Car Entertainment + Electronics (audio / video / alarm) 18 03-23-2016 02:27 AM
Removing the Glove Box in a 2014 LE Eforno Third Gen Yaris General Discussion 4 12-24-2014 05:46 PM
Glove box damper... where does it connect? kmtodd4 Third Gen Yaris General Discussion 5 10-15-2014 09:33 PM
Advantage Drivers Side Glove Box! bronsin General Yaris / Vitz Discussion 15 02-18-2014 01:42 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 02:45 AM
