Old 08-07-2017, 12:28 PM   #1
rabbito
rabbito's Avatar
Originally Posted by tmontague View Post
The issue with not getting power to 7k rpm had nothing to do with your fuel cut off. Well technically you would have no power above the fuel cut off but in this case where you have raised the cut off to 7k you could still experience a loss of power unless you've tuned for it
Most engines that are for economy cars are tuned to have more low end power so after a certain rpm the paower band drops right off making it inefficient to shift right to red line.
I know when I had my 1nz after about 5.5k rpm it would fall on its face (with all flow mods) so I would shift no later then that normally. On the 2zr it pulls like a train almost right to the fuel cut off so I shift up to that point. This is likely due to having dual vvti where as the 1nz only has vvt On the intake (iirc)
Engines are designed to run within their factory determined rev range, taking it to red line is fine as long as you meticulously maintain your engine. If anything it will help keep carbon off of your valves and keep your head cleaner.
In your case you've raised the rev range so it is a risk but toyota tends to have large buffer zones so going up .6k rpm should be ok
thank you for your reply
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
2009 Toyota Yaris Absolute Red Golddeenoh Cars for Sale by private party 26 03-23-2017 11:02 PM
Red Yaris from Jakarta allyart Photo-Video-Media Gallery 20 07-21-2012 03:47 PM
Red Line Synthetic Gear Oil EjDaPogi Middle East 31 07-04-2011 07:56 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
Where can a sister get RED floor mats and seat covers death is my gift Cosmetic Modifications (Exterior/Interior) 12 09-17-2007 02:11 AM
