Old 08-09-2017, 01:23 PM   #1
xdarkxfirex
Drives: 2015 yaris le
I spun it manually also and noticed a little wobble. At first i assumed it was the bead incorrectly seated against the rim or cone on balancing machine misaligned. I spun it manually and indeed there is some runout. Might need to get me a dial gauge and a mount to measure it. As far as I know, .050" or 1.25mm is the tolerance.
xdarkxfirex is offline   Reply With Quote
Old 08-10-2017, 06:18 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Actually.. the weight are there to offset the balance at speed. So if you see it wobble at low speed by spinning it and looking at it. Well, it's always going to do it.
Tires are not perfect, so are rims. Sometimes, the rim and the tire is so well aligned they don't require any weight to keep balanced. But doesn't mean tires are always perfect.
Also, anything under .25oz is considered balanced. But also is worth installing a .25oz weight if it's unbalanced by say .20oz. it depends on the garage. I have one at .21oz
Sent from my SM-G930W8 using Tapatalk
New Rims on my Yaris S ev_yaris_s Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2011 10:59 PM
wtb: factory rims kid chino Willing to Buy by private party 2 01-21-2010 09:10 AM
Got a Yaris and want some rims... help for a new guy please. 47_MasoN_47 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-17-2009 06:17 PM
