![]() ![]() Drives: 2012 Yaris L MT Join Date: May 2012
Follow up.
The third brake light pops out fairly easy. Just squeeze the large metal clips that wrap round the back side of the light. Squeeze them as close to the sheet metal as possible. Once removed, the original gasket was completely destroyed. It was hard as a rock, smashed flat and full of cracks. I peeled it off, liberal amounts of goo gone were required to get the backing tape off. Once all was cleaned up, I made a new gasket using household foam weather stripping. Had to some trimming here and there, but it is not leaking anymore. |
| 2008 toyota yaris 2 door hatchback water leak | knobby bobby | DIY / Maintenance / Service | 8 | 07-03-2024 07:42 AM |
| Water leak to passenger side AND driver side | TMR3 | DIY / Maintenance / Service | 7 | 05-21-2017 08:19 AM |
| Water leak problem | Yaris874 | General Yaris / Vitz Discussion | 5 | 04-10-2017 01:03 PM |
| Water leak in Hatch | ilikerice | DIY / Maintenance / Service | 40 | 10-22-2016 03:46 AM |
| Water Leak! Failed Relays | cfeng | DIY / Maintenance / Service | 0 | 12-13-2010 06:21 AM |
