Old 08-29-2017, 03:39 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by rabbito View Post
my car can stay up to 7000rpm with stock valvetrain and spring..you need to change spring etc. when you pass 7000rpm..i dont have enough money to do that lol...valve and spring parts are pretty expensive..
Sent from my SM-N920C using Tapatalk
I'm running stock springs with ti retainers to 8k and no float but I wouldn't go much higher than that and I don't suspect the springs will last all that long.
Cams are 236@.05 with .36" lift. Still makes power at 8k but the stock intake and TB have given up by that point.
2014 BSpec Divisional Champion
Old 08-30-2017, 10:38 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
are you using piggyback or standalone? how much did you gain? im going to be on dyno and retune my ecu this saturday..
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 08-30-2017, 02:08 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'm running a AEM series 2 that piggybacks off throttle, but is fully controlling cam\ignition\fuel.
Its hard to say how much I gained because it was a new motor with quite a bit of work done to match the rules for the class I race in. My peak power changed from 5.9k to 7k and stays flat until I shift at 8k but thats mostly due to running out of air from the intake man and tb.
$105 Track day @ Willow Springs- Big Willow Dec 21st judd Tracking, Racing, Auto-X Forum 0 12-14-2013 11:50 PM
Memorial Day Weekend Meet/Picnic in Southbury, CT? CTScott New England 10 07-25-2013 11:47 PM
Nice day out..new Yaris pic detroiter Photo-Video-Media Gallery 2 03-18-2013 10:26 PM
Labor Day Weekend in Malibu/Rock Store (do people still have 56k?) AdeJong 03 Photo-Video-Media Gallery 15 09-09-2009 06:17 PM
