Old 08-31-2017, 09:54 AM   #1
tmontague
tmontague's Avatar
No, it was red poly. It was also much bigger in size as It has to replace the big rubber bushing in the yaris doggone. It does however have the metal sleeve in it
Old 08-31-2017, 09:57 AM   #2
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
https://www.ecstuning.com/b-ecs-part...5.1105r~round/
edit:
why dont you just spend more money and order the VITZ TRD engine mounts from japan?
DarkShadowFox is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
bushing came off metal sleeve on rearstrut? tein coilover TRD.RiC Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-18-2012 10:14 PM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 10:12 AM
