![]() Drives: 2006 Yaris Hatchback 4DR Join Date: Mar 2012
Hi all, I have these same codes on my 06 hb. (285,000 km, sometimes top it off, but the canister is dry & fills easily. We do not see or smell any gas leaks).
System does not hold a vacuum & leaks pressure at the filler cap (1 psi). How much pressure should the system be able to hold? Gas cap vacuum valve will hold aprox 2-3"hg. First thing I checked was the purge valve in the intake system, it was open. During testing it closed & I have rechecked it and it was still closed. Then pres tested gas tank. sprayed everything with soapy H20. Only leak I found was the gas cap seal. ( looks like it Is not mean to hold psi). Vac tested entire system & will not hold anything. Does any body have any answers? or knowledge or manual for indepth testing? Any help would be appreciated, Jason |
#2 | |
| Vapor Canister | Crashmaster | DIY / Maintenance / Service | 25 | 03-11-2014 10:18 AM |
| Found this 2014 Mitsubishi Mirage ES yesterday | Hershey | Off-topic / Other Cars / Everything else Discussions | 97 | 01-30-2014 11:30 AM |
| What are these codes Yaris sedan is throwing? | detroiter | DIY / Maintenance / Service | 2 | 11-28-2012 11:44 AM |
| DTC's P043E & P043F | 03Z33 | DIY / Maintenance / Service | 10 | 04-06-2007 12:13 AM |
