Old 09-14-2017, 09:53 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
I believe there are 2 wires to join to the blue wire of the new HU to make this work correctly
Old 09-14-2017, 05:01 PM   #2
weevil
Drives: 2013 Yaris YRS
Well that's a very tantalising post 'n' all Illusion. Any clue as in which two? ;)
This is the harness the manufacturer sent me. it actually has two wires, they told me to connect both of them to 12v. They are not actually connected to the blue wire on the head unit but surely that does not matter.
The wiring going into the antenna looks like this with the 12v going to the pin in the middle of the plug.
weevil is offline   Reply With Quote
Old 09-15-2017, 07:25 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The blue wire in that adapter is the power feed to the antenna amplifier. From memory, this is a black wire parallel to the actual antenna cable. The radio normally feeds 12v to this wire. If there is no 12v feed to this, you will have very poor radio reception. Look for a switched power output from the radio. This will possibly be labelled as being for amplifier switching. Connect this to the antenna amplifier wire.
I missed this one when I installed an aftermarket radio. Once I found it, the reception was almost as good as the stock radio.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 09-15-2017, 07:35 PM   #4
weevil
Yep that is my understanding too, I have tested the wire and it’s definitely getting 12v but the signal is still nowhere near the factory unit.
2012 YARIS HB poor radio reception code54 In Car Entertainment + Electronics (audio / video / alarm) 5 12-19-2015 10:46 AM
Add USB audio to factory head unit Gladmo2 In Car Entertainment + Electronics (audio / video / alarm) 8 01-02-2013 11:25 PM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-01-2010 11:13 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
