Old 09-14-2017, 08:14 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
Testing for spark the old way?
Can we pull a coil pack, then it's plug, then reassemble where the plug is visible (with plug base grounded) and crank it over to see if there's spark?
Old 09-14-2017, 08:26 PM   #2
robkay
Drives: Hatch
Gosh, I'm not sure what a "coil pack" is. I remember the old way of pulling a plug wire and holding it close to the spark plug, then having someone turn the key to see if it generates a spark. (Sometimes generating a in the process.)
I've never actually dug far enough down in there to see where the plugs are on this car. Maybe you could elaborate for me?
robkay is offline   Reply With Quote
Old 09-15-2017, 08:52 AM   #3
dogsridewith
spark testing historically
Responding here only to "old-way" parts:
If held next to the wire end of the plug, then the system needs to spark two places to make any spark. Also many plug-wire ends have metal up inside a non-conductive rubber boot cover. Alternative is to remove plug, install plug-wire, and lay/restrain the thread end of the plug to the head...or wire it to something metal.
To start or not to start? Doix DIY / Maintenance / Service 11 12-10-2023 08:30 PM
2007 Sedan suddenly won't start acyaris DIY / Maintenance / Service 12 12-08-2014 09:37 AM
Remote Start Bug, please help jeeper5usa In Car Entertainment + Electronics (audio / video / alarm) 5 01-02-2014 08:36 PM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 10:02 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
