#1 | |
I was underneath my car today and found a couple of oblong rubber plugs just in front of the rear wheel, just inboard of the rocker panel. There's quite a large cavity in there. I sprayed Rust Check Red in those cavities - about 1/3 of a can in each and replugged. This section appears to be separated from the regular rockers as all the ATF I dumped in there the other day didn't make its way into these cavities.
Tomorrow's Job
Tackling the brakes tomorrow. I don't anticipate any major issues having had the drums off a few days ago. The pads on there now are actually in pretty good shape. The drums are, I expect, the originals and are pretty rough looking. I plan to paint the drums with a few coats of ceramic header paint. I do this to my calipers and rotors on my cars. Then, once a year, I'll clean them up and respray. If you don't do this in our climate, they look like absolute crap after a winter or two.
#3 | |
#4 | |
I would love to get ahold of a few of those! I had a flexible wand with 360 degree tip on it for use with FF. There is an outfit call Kellsport that sells these. Also, I've seen them on Amazon and Ebay. I really loved mine as it did an amazing job of 360 degree product application. The unfortunate thing is the tip on mine got lost inside a unibody subframe member despite my best efforts to carefully remove it. I did manage to do a couple of cars with it before I lost the tip.
| Car Maintenance, Service etc | lijet | DIY / Maintenance / Service | 4 | 04-10-2012 07:39 PM |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 09:00 PM |
| 60K Mile Maintenance | Pattycake | DIY / Maintenance / Service | 20 | 11-17-2009 02:34 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 03:14 PM |
