Old 09-27-2017, 09:22 PM   #1
kiimboy
Drives: 2009 Toyota Yaris Sedan
Is the post cat one the downstream? Sorry, a car noob here lol
kiimboy is offline   Reply With Quote
Old 09-27-2017, 09:52 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, the post cat is the downstream 02 sensor. I am going the plug defouler route since my air fuel ratios are solid. I picked a kit up this evening.
Old 09-27-2017, 10:36 PM   #3
kiimboy
How do i check my air fuel ratio?
Old 09-28-2017, 08:12 AM   #4
06YarisRS
I'm using my OBD 2 bluetooth adapter, Torque Pro app on my android phone. Among many other sensors monitored are both commanded AFR and measured AFR. I am in Niagara Falls now but when I return home in a couple of days, I could send you a pic if interested.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
PO420.....so now what? la_scanner DIY / Maintenance / Service 45 04-14-2011 03:18 PM
