Old 09-28-2017, 11:54 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by imran.niaziccl@gmail.com View Post
Yeah first thing mechanic did was cleaning the throttle body but still same
Is there any way I can increase the idle rpm of the car?
Idle should be about 550rpm. And 800rpm with AC with a warm engine.
Mine idles at 1100rpm on a cold engine.
I've read alot about people complaining about the idle fluctuating on this engine.
Also, did you check PCV?
Sent from my SM-G930W8 using Tapatalk
Throwing codes P043E, P043F, P2401, P2402, P2419 47_MasoN_47 DIY / Maintenance / Service 17 10-14-2017 01:19 AM
:( Check Engine Light with dropping Rpm imran.niaziccl@gmail.com DIY / Maintenance / Service 9 06-01-2017 04:30 AM
Which parts chain = best 2C re throwing codes?...Or is dlr w/Techstream needed? nookandcrannycar DIY / Maintenance / Service 4 01-18-2015 09:18 PM
What are these codes Yaris sedan is throwing? detroiter DIY / Maintenance / Service 2 11-28-2012 12:44 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 05:40 PM
