Best bet is to cut out the rust and weld in new metal. You need to treat the other spots too. I like fluid film. Anything will be better then nothing.
![]() ![]() Drives: Toyota Yaris 2007 Sedan Join Date: Sep 2017
Probably the best bet. However, if you want to DIY, fiberglass offers an excellent, non-rusting, alternative to welding in steel. Any steel you weld in will still be subject to rusting - especially where welded - and it can be harder to ensure a water tight seam when welding metal in. Personally, if it were my car, and I was trying to save money, I would go the fiberglass route. In either case rust removal, and maybe conversion (phosphoric acid) would be sound preparation. Whichever approach you take, I would absolutely avoid putting any kind of rubberized (drying) undercoating over your repair. That is simply asking for water penetration and accelerated rusting.
Ex-x-Fire makes a great recommendation in rustproofing product. Fluid Film is an excellent and relatively long-lasting product. Best of luck. And please document if you can.
| Current State of Rust: 10 years above the salt belt | fourbangingfun | DIY / Maintenance / Service | 12 | 03-23-2019 08:28 AM |
| Rust Inhibition - What do you all do? | tmontague | DIY / Maintenance / Service | 9 | 03-05-2016 01:02 AM |
| Yaris Rust Repair Questions | GrayYaris | DIY / Maintenance / Service | 8 | 10-31-2014 06:58 PM |
| Rust Proofing Decision ? | YodaBird | DIY / Maintenance / Service | 3 | 04-11-2013 10:55 AM |
| Rust Protection | casterqc | General Yaris / Vitz Discussion | 12 | 09-20-2010 11:09 PM |
