Old 10-04-2017, 09:51 AM   #1
Spellino
Drives: Toyota Yaris 2007 Sedan
Originally Posted by ex-x-fire View Post
Best bet is to cut out the rust and weld in new metal. You need to treat the other spots too. I like fluid film. Anything will be better then nothing.
I guess it means a trip to the welder
Spellino is offline   Reply With Quote
Old 10-04-2017, 03:47 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Probably the best bet. However, if you want to DIY, fiberglass offers an excellent, non-rusting, alternative to welding in steel. Any steel you weld in will still be subject to rusting - especially where welded - and it can be harder to ensure a water tight seam when welding metal in. Personally, if it were my car, and I was trying to save money, I would go the fiberglass route. In either case rust removal, and maybe conversion (phosphoric acid) would be sound preparation. Whichever approach you take, I would absolutely avoid putting any kind of rubberized (drying) undercoating over your repair. That is simply asking for water penetration and accelerated rusting.
Ex-x-Fire makes a great recommendation in rustproofing product. Fluid Film is an excellent and relatively long-lasting product.
Best of luck. And please document if you can.
Current State of Rust: 10 years above the salt belt fourbangingfun DIY / Maintenance / Service 12 03-23-2019 08:28 AM
Rust Inhibition - What do you all do? tmontague DIY / Maintenance / Service 9 03-05-2016 01:02 AM
Yaris Rust Repair Questions GrayYaris DIY / Maintenance / Service 8 10-31-2014 06:58 PM
Rust Proofing Decision ? YodaBird DIY / Maintenance / Service 3 04-11-2013 10:55 AM
Rust Protection casterqc General Yaris / Vitz Discussion 12 09-20-2010 11:09 PM
