![]() ![]() Drives: Toyota Yaris 2007 Sedan Join Date: Sep 2017
What are these for?
Found them while removing the carpet under the driver seat. They were to the right. It's a 2007 sedan
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
Maybe connectors for the optional Interior Light kit:PTS21-52062-08 They look similar than the ones show in pages 9 and 10, and the location is quite the same, but the kit if for both sides and normaly a switch is installed close to the parking brake.
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
wow. i didn't know that. here they are
https://parts.rosevilletoyota.com/p/...wd=&origin=pla |
Probably the seat belt sensor. Do you have any strange lights on?
Sent from my SM-G930W8 using Tapatalk |
Just the SRS warning light and the hazard light not working. I had and electrical professional install an alarm. Don't know if that has anything to do with it
#6 | |
You might want to have it checked out. Pretty sure the SRS light is caused by the absence of a signal from the seat belt buckle and seat sensor.
Is a optional accessory made by Toyota and normaly installed by dealers.But as IllusionX said it could be a seatbelt sensor, those have similar construction and is worth checking where they go.
I am just judging by the form of the connector and the location, need to check my car but mine doesn´t have sealtbelt chime or sensor. |
