Old 10-13-2017, 04:12 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
My idle voltage is 14v.
Sent from my SM-G930W8 using Tapatalk
Old 10-13-2017, 04:30 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
+1, Now that I installed a reman alternator. It was in the mid 13s before replacing.
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
possible alternator (voltage regulator) issue jesse1000 Canada 3 03-09-2009 09:10 PM
