![]() Drives: 2008 Yaris S Hatchback Join Date: Oct 2017
I was able to cut away the bolts between the flanges, but will need a longer drill. I replaced the donut gasket and clamped it shut with a U bolt until I come back to it after purchasing the correct parts
Noise is gone, but now I have a P0031 fault code. I wonder if I damaged the O2 sensor while messing around? nightmare fuel |
Maybe the wiring which is not far from the flange. Could you have nicked a wire with your drill bit? The downstream sensor has 4 wires. Not sure about the upstream wideband sensor.
![]() Drives: '10 Hatchback Join Date: Dec 2016
Same thing happened to me. I was able to helicoil it by using an adapter to hold the bit/tap/helicoil tool to a 12" extension bar.
| Newbie with an exhaust leak on his '06 Yaris | ToYarta | DIY / Maintenance / Service | 49 | 01-03-2019 12:50 PM |
| My Echo Exhaust Leak in Front ? | frank2005 | General Yaris / Vitz Discussion | 8 | 08-02-2017 08:52 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
