Old 10-29-2017, 06:51 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
If you post the actual OBD2 code, someone might be able to help. P0xxx?
I think there are a few speed sensors, wheel hubs, transmission output sensor.
Also, I thought I read a post about a brake booster causing the engine to idle very slow at a stop.
I had a similar problem with my 2006 Dodge Grand Caravan. Engine would buck, then stall at a stop light. It turned out to be a plugged charcoal canister. Too much vacuum in the fuel system was starving the engine of fuel. I unplugged the purge solenoid intake valve hose, put a fuel filter on it and the problem went away.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Yaris Gearbox gear change problem? slnko2003 General Yaris / Vitz Discussion 1 08-20-2012 01:26 PM
