Old 11-03-2017, 10:53 AM   #1
Randy_84
Drives: 2010 yaris rs manual
Query
I also have a squealing in my 2010 yaris rs liftback. When i turn the air condition on it squeals for about 25 seconds then stops. If i driving with the a/c on and i have to stop, as I shift the gears down, the squeal returns. Even at times when drive to a spot and then put the car in reverse it squeals. The belt has been changed before, but it still kept the noise. I just want to know if the belt is tensioned, would that solve the problem.....any feedback?
Randy_84 is offline   Reply With Quote
Old 11-04-2017, 09:53 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Toyota Yaris serpentine belt tighten tension
Should have been re-tensioned the first time it squealed for 25 seconds. Or 3 seconds. And if that doesn't solve, then look for driven items seizing up...like A/C compressor. Does it chirp or squeal at startup w/ the A/C off?
Old 11-08-2017, 10:17 AM   #3
Randy_84
The A/C compressor was change like a year ago. It chirps or squeals occasionally when at startup and when the A/C is turned on it chirps as well. There are times when i startup, leave the car running for 60 seconds and then turn the A/C on and I get no squeal. It is suppose to get look at within the coming weeks, so hopefully i would get the problem fixed.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
Supercharger Belt Slip Possible fix quemoto Forced Induction Forum 20 03-04-2011 02:55 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
