![]() Drives: The ori 1nz-fe with some mod Join Date: Nov 2017
1zz throttle body error
Hi all 1nz bro
I tried to swap my 1nz baby throttle body to 1zz adult throttle body, and I has been successfully install and start. But...the engine check light on, the rpm of car cnt going up and max is 2k rpm. Before install I has been wrongly pressed the butterfly plate. Do my throttle body gone ? I find the seller back but he don’t want to return because I wrongly press the butterfly plate. Please help, I’m stuck!!!! |
#2 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
if you done all this and have issue, i dont think your tb isnt fully opening...well thats a problem right there man..... Sent from my SM-J730GM using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
no need computer reset???
i cnt do it bro, i already reset battery negative. or my tb is broken? the seller said is me press the butterfly plate in tb so tb need reset ***help*** |
#4 | |
#5 | |
feed my pet
| 1zz or 2zz throttle body swap | BoostedTRD | Performance Modifications | 1 | 11-25-2014 10:05 AM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| Throttle Body Swap | Ryze268 | Performance Modifications | 12 | 04-27-2014 01:46 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
