Old 11-13-2017, 01:36 AM   #1
Bigbenzzz
Drives: The ori 1nz-fe with some mod
no need computer reset???
i cnt do it bro, i already reset battery negative.
or my tb is broken?
the seller said is me press the butterfly plate in tb
so tb need reset
***help***
Bigbenzzz is offline   Reply With Quote
Old 11-13-2017, 01:52 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
or my tb is broken?
so tb need reset
***help***
tb need reset....how....doesnt make sense...only open or close by idle screw...if it doesnt flap, its broken...
Sent from my SM-J730GM using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
1zz or 2zz throttle body swap BoostedTRD Performance Modifications 1 11-25-2014 10:05 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
