#1 | |
I have not closely checked the control arm bolts but I did coat them in Rust Check Coat and Protect. Everythng seemed fine but I'll pop a wrench on them and check. Thanks for the heads-up!
#2 | |
![]() Drives: 2008 yaris hb ce Join Date: Jul 2011
I broke a 3/8" ratchet on the driver's side bolt. Then I used a 1/2" ratchet and that broke the bolt head off. I think if I would have torched the bolt head first it may have come off without breaking the bolt head. Of course heating up bolt head may destroy your rubber bushing...so you need to decide if this approach is best for you. Once I broke the bolt head off I needed to drop the subframe to get at that bolt. In the process, I ended up destroying the control arm bushing, and ended up replacing the control arm. I coated the new bolts with lithium grease so I hope they will last another ten years! Good luck! |
| Rear cabin grommet | carbine2 | DIY / Maintenance / Service | 0 | 04-28-2014 07:02 AM |
| OEM roof rack mounting rubber pad replacement | Yai | Cosmetic Modifications (Exterior/Interior) | 3 | 12-22-2012 01:01 PM |
| MY RUBBER BAND BALL! AGHHH!!! | Sodium Duck | Off-topic / Other Cars / Everything else Discussions | 47 | 03-06-2009 02:56 AM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 05:48 AM |
| Noise coming from rear end! | tfman716 | General Yaris / Vitz Discussion | 15 | 10-28-2008 01:37 PM |
