![]() Drives: 2008 yaris hb ce Join Date: Jul 2011
Blank rubber grommet
I recently noticed three holes in the bottom of the frame rails that reside under the front driver and front passenger area. Should these holes have blank rubber grommets similar to the grommets that are used in the floor pan?
The next time you happen to be under your car could you please take a look and let me know if you have these holes plugged? My car is 2008 Yaris hatchback CE. Thanks! |
やりすぎだ~
Yes, they're supposed to be plugged.
I would not plug them. Water can get into these rails along where they join the floor pans. Plugging the holes traps the water and allows rust to propagate unhindered. Spray a rustproofing oil of some kind in there. Even used motor oil will help. Something like fluid film would be best. It's so easy to do with the spray cans.
Frame rail holes are not plugged. Floor pan holes yes, frame rail no.
Thanks yarisugi, 06YarisRS and WeeYari for the reply. I do live in an area that gets snow and salt on the road, so that was something I was wondering, is it better to have those holes plugged or unplugged.
So far it doesn't look rusty around those holes. Spraying oil/grease/fluid flimn into the frame rail holes is probably a good idea. While I was down there I did notice rust around the plugs in the floor pan, so I removed those plugs and painted around the area, and then put some grease on the plugs and put them back in. I will need to take the carpet out sometime and see if there is any rust on the floor pan inside of the car. I hope water and salt is not making its way into the floor pan inside the car. Thanks again for the replies! |
#6 | |
#7 | |
I also have used rubber floor mats inside the car since it was new, so I don't think any water/salt would be coming from shoes/boots. I hope there isn't any other source of water inside. |
#8 | |
On a similar note, today I drilled my rocker panels and also drilled holes just below the door latch on the rear doors of my 08. I dumped about a liter of ATF in each rocker panel and sprayed rust check in the rear holes to soak the rear panel, wheelhouse and dogles areas, then plugged them with the 1/2" body plugs. The atf dripped out all along the rocker, so it should be well protected against this winter's salt attack. EDIT: So that the environmentalists among us don't get upset, I collect all drips into containers and recycle it.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-14-2017 at 08:03 AM. |
#9 | |
So far no rust on the body, but surface rust has started on the underbody. Did you inspect the lower control arm bolt on your car? I did that recently, and needed to replace both of those bolts. The passenger side bolt came out in one piece, but on the drivers side the head broke off. It wasn't a fun job replacing that bolt.
#10 | |
I have not closely checked the control arm bolts but I did coat them in Rust Check Coat and Protect. Everythng seemed fine but I'll pop a wrench on them and check. Thanks for the heads-up!
#11 | |
I broke a 3/8" ratchet on the driver's side bolt. Then I used a 1/2" ratchet and that broke the bolt head off. I think if I would have torched the bolt head first it may have come off without breaking the bolt head. Of course heating up bolt head may destroy your rubber bushing...so you need to decide if this approach is best for you. Once I broke the bolt head off I needed to drop the subframe to get at that bolt. In the process, I ended up destroying the control arm bushing, and ended up replacing the control arm. I coated the new bolts with lithium grease so I hope they will last another ten years! Good luck! |
| Rear cabin grommet | carbine2 | DIY / Maintenance / Service | 0 | 04-28-2014 07:02 AM |
| OEM roof rack mounting rubber pad replacement | Yai | Cosmetic Modifications (Exterior/Interior) | 3 | 12-22-2012 01:01 PM |
| MY RUBBER BAND BALL! AGHHH!!! | Sodium Duck | Off-topic / Other Cars / Everything else Discussions | 47 | 03-06-2009 02:56 AM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 05:48 AM |
| Noise coming from rear end! | tfman716 | General Yaris / Vitz Discussion | 15 | 10-28-2008 01:37 PM |
