When I swapped my C160 into my car it was a bell housing swap and frame notch to get it to fit. The C60 is virtually identical, except there are a couple different versions. Mostly just forward mount or rear mount shift cables. The C60 also uses larger axles splines vs the C160 which is why I went with the C160. I was able to retain the stock axles.
Good luck with the swap. You'll really enjoy the ultra short gearing for track duty. |
#2 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Do you have any idea what axles I'll need for the C60 differential? I'm thinking of trying a set of xD axles first, unless there is a reference somewhere for spline specs? |
#3 | |
Are you using stock yaris axles now with stock hubs? |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
