Old 11-15-2017, 12:50 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Originally Posted by Bluevitz-rs View Post
When I swapped my C160 into my car it was a bell housing swap and frame notch to get it to fit. The C60 is virtually identical, except there are a couple different versions. Mostly just forward mount or rear mount shift cables. The C60 also uses larger axles splines vs the C160 which is why I went with the C160. I was able to retain the stock axles.
Good luck with the swap. You'll really enjoy the ultra short gearing for track duty.
Interesting.
Do you have any idea what axles I'll need for the C60 differential? I'm thinking of trying a set of xD axles first, unless there is a reference somewhere for spline specs?
Old 11-16-2017, 12:03 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by ArmstrongRacing View Post
Interesting.
I have a first gen, so your application might be different.
Are you using stock yaris axles now with stock hubs?
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
