Just read your blog...
You might just need to swap the diff from the 5 speed and you'll be all set as the axles fit it already. C60 uses an 8 bolt diff, so if the C50 has the same thing, all you should need to do is change the ring gear. |
#2 | |
2ZR swap. DO IT! Ask how!
From what I can see online, the spline counts from the xD are correct. Not sure about diameter and length of the insert stub, or if it's the same diameter, but I'd be willing to bet that they will work. Last edited by CrankyOldMan; 11-16-2017 at 09:39 AM. |
#3 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
