Old 11-16-2017, 09:22 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by Bluevitz-rs View Post
You might just need to swap the diff from the 5 speed and you'll be all set as the axles fit it already. C60 uses an 8 bolt diff, so if the C50 has the same thing, all you should need to do is change the ring gear.
Sadly, there are two different sized 8-bolt differentials. I learned that the hard way when I bought the wrong Quaife LSD and had to pay a 25% restock fee. The larger displacement engines use an 8-bolt diff with a different diameter shoulder for the final drive ring gear and a different spline count in the spider gears. It might be possible to swap spider gears (I could check using the spare diffs from my gearbox teardown) but it's easier to just find an OEM axle that works.
From what I can see online, the spline counts from the xD are correct. Not sure about diameter and length of the insert stub, or if it's the same diameter, but I'd be willing to bet that they will work.
Old 11-16-2017, 11:25 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Awesome Sam, thank you. I'm assuming at this point all of the sub-compact Toyotas use a 23 spline axle, and the regular duty cars like the corolla, use the 20 spline. It looks like the Scion xD has once again become a very important part of the Yaris swap project
ArmstrongRacing is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
