Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
6 speed swap project
Hey guys, I didn't want this info to get lost at the end of my 2zr swap thread so I started a new one. I'm using a C60 close ratio 6 speed transmission from a 2003 Toyota Celica GTS.
Check out the first writeup here: http://www.armstrongfamilyblog.com/a...mission-faster Part 1 | C60 Teardown: http://www.armstrongfamilyblog.com/a...-c60-tear-down Part 2 | C60 repairs: http://www.armstrongfamilyblog.com/a...ion-and-repair Part 3 | C60/C50 Case Fitting: http://www.armstrongfamilyblog.com/a...final-assembly Part 4 | C60 Install and Axles: http://www.armstrongfamilyblog.com/a...-initial-tests *THE VIDEO* Toyota Yaris 6 Speed Swap | First Drive: https://youtu.be/lEvpjvi1w8A
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 12-17-2017 at 10:25 PM. |
When I swapped my C160 into my car it was a bell housing swap and frame notch to get it to fit. The C60 is virtually identical, except there are a couple different versions. Mostly just forward mount or rear mount shift cables. The C60 also uses larger axles splines vs the C160 which is why I went with the C160. I was able to retain the stock axles.
Good luck with the swap. You'll really enjoy the ultra short gearing for track duty. |
This absolutely warrants it's own thread. The short vid ending with your smug mug got a chuckle out of me, too lol.
Giddy up!
#5 | |
Data doesn't lie
Do you have any idea what axles I'll need for the C60 differential? I'm thinking of trying a set of xD axles first, unless there is a reference somewhere for spline specs? |
#6 | |
Are you using stock yaris axles now with stock hubs? |
Just read your blog...
You might just need to swap the diff from the 5 speed and you'll be all set as the axles fit it already. C60 uses an 8 bolt diff, so if the C50 has the same thing, all you should need to do is change the ring gear. |
![]() Drives: Echo 05 Join Date: Oct 2017
In my Echo, i was able to use the stock axle in a C59 5speed bolted to my 1zz, every where i read the conversion 5 to 6 speed c60 would not need new axles on a corolla or vibe based car.So i would be able to fit the stock axles in the c60 in Theorie. You guys agree?
Theres a guy here in quebec, used the 2zz axles in a yaris hub and stock 5speed trans. Are the axles from vibe,celica, and matrix all the same? |
#9 | |
2ZR swap. DO IT! Ask how!
From what I can see online, the spline counts from the xD are correct. Not sure about diameter and length of the insert stub, or if it's the same diameter, but I'd be willing to bet that they will work. Last edited by CrankyOldMan; 11-16-2017 at 09:39 AM. |
#10 | |
Data doesn't lie
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
![]() Anxiously waiting to see what you come up with this time.. -- Adam |
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
4.5 fd sounds nice. My only gripe about the c60 is the shifter feeling sucks.
If you lack driver skill, add horsepower. |
Data doesn't lie
Thats odd, since the C60 and C50 have the same shift mechanism inside the trans. It must be something related to the C60 not having counter weights on the end of the shift rod, where the C50 does.
#14 |
Data doesn't lie
OK guys, here is Part 1 of the 6 speed project, C60 teardown and comparison.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-22-2017 at 01:13 AM. |
#15 |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
MOAR
https://www.instagram.com/3cyltrbo/ |
#16 |
Data doesn't lie
I had to replace some synchros but ill update the blog with Part 2 this week. Thats the gamble with junk-yard transmissions, no big deal though.
#17 | |
dude thanks for documenting all this. ....you say that you got the tranny from a junkyard, did you price them out brandnew first? / I'd be curious to know if Toyota transmissions are cheap like Honda transmissions? (ie: you can get a brandnew B-Series transmission for like $1800)
#18 | |
Data doesn't lie
ALSO Blog is updated with Part 2! Getting closer my dudes! http://www.armstrongfamilyblog.com/a...ion-and-repair
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-22-2017 at 01:17 AM. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
