Old 11-25-2017, 11:29 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If the length of the threads of the new stud is 10mm longer than the original one then you're good.
The new stud length should at least make up for the thickness of the spacer.
Dont confuse hub spacers with wheel spacers.
Old 11-26-2017, 11:38 AM   #2
Pinchlite
Drives: 2007 yaris HB
The original is 39.87 mm under head length.The new ones are 50(Approx)underhead.
Should be good to go.
Pinchlite is offline   Reply With Quote
Rear Wheel Spacer Help 10mm pinhead123 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 11-25-2017 09:45 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Longer wheel studs for 5mm spacer? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-09-2013 10:35 PM
FS: Sparco Wheel, Quick Release, Momo Spacer Focus_Sh1ft Items for Sale by private party 18 04-27-2011 12:36 AM
