Old 11-27-2017, 03:18 AM   #1
zoidberg444
zoidberg444's Avatar
Thanks zoidberg444. I plan to order the Continental belt. I'm getting a little nervous about having the Dayco cranked up so tight.
I found this document but not really sure how I would measure it effectively. I'd likely go with the belt deflection at point B, but how to determine 22 lbs, I'm not sure.
https://www.gates.com/~/media/files/...in-pa01112.pdf
EDIT: After looking at a hardware website, I may pick up a small spring scale with a hook. Canadian Tire has a 50 lb scale for a decent price. I could run a straight edge across the pulleys joining section B, pull down on the belt with 22 pounds and measure deflection.
Yeah. You should be careful overtightening the belt because you could burn out the bearings on the pulleys if you leave it like that for a while.
To be honest. When I did it, I used my calipers and opened them to 11mm. Positioned them roughly in the middle of the belt and then tugged with my finger to measure the deflection. Not to hard and then eye balled it. Seems to have worked pretty well. I'd start a little loose and then maybe add some tension if it squeals.
Sent from my SM-T713 using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 11-27-2017, 05:59 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, however I do it, I will do it soon. I'm going to look through our shop today and see if we have any kind of scale that I can use. And, I'll follow your advice of starting looser and adding a bit of tension each time to eliminate squeal. Thanks.
Serpentine belt squeals on cold start up after replacement. YarYarBinks DIY / Maintenance / Service 16 03-03-2017 10:04 AM
New Serptine Belt Squealing aaron21339 DIY / Maintenance / Service 11 10-14-2016 11:43 AM
Belt Squeeling like a Mofo gumby002 DIY / Maintenance / Service 7 09-10-2016 05:38 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
