Old 11-28-2017, 03:37 PM   #1
mr_robot
Drives: Yaris
How about if I roll my fenders?
mr_robot is offline   Reply With Quote
Old 11-28-2017, 06:33 PM   #2
tmontague
tmontague's Avatar
Fwiw I have -2.7 up front and -2.0 camber in the rear and I have 10mm penguin spacers in the rear. I'm lowered on micro image springs that have since sagged and I had zero run on the stock 185 width rubber. I had much more room available up front than in the rear due to more camber up front and rear spacers
I rolled my rear fenders to fix minor rub from my track wheels (15x7 +24 on 205 wide rubber) and I have a lot of room to fit a wider set up.
I will be running 7.5" wide rims +35 with a 205 wide tire this summer. Technically it's a 195 wide tires but the sport comp 2's measure actual width the same or wider as most 205's. This set up won't help you as I won't be able to give you feed back until the spring time, but my previous set up might be of help to you.
Side note, there is not much fender to roll on the yaris. I tried to do a bit of "pulling" when i rolled mine and it worked a bit but I used a heat gun to heat it up really well
Which way i go? I will be on 16x7.5 +35mm rim. Will i be on 205/50/16 or 195/50/16 daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-15-2014 02:12 AM
Help! Tein S-tech with 195/55/15 will it rub?? evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-21-2009 09:59 PM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
