Old 12-01-2017, 04:46 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
9mm 1/4" drive fits. I suspect you need some type of spanner to hold the pulley assembly stationary while working the socket.
When I talk about working within confines, I'm referring to attempting pulley removal with the compressor still mounted. It should also be noted that the clutch is internal. That outer disk on the pulley that looks like a clutch is not.
Ah, I see. The pulley is solid then. I stand suitably corrected. Much to learn about these fine autos. Thanks.
