Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Excellent score on parts.
Factory the oil pan is glued (siliconed) when I had mine apart to install a drain fitting for future turbo use I cleaned it off and used Permatex Ultra Grey.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#2 | |
I was looking through my service manual yesterday and found a diagram of the RTV sealant aplication. I used to go around each bolt hole in a little circle, but Toyota has us using a semi-circular bead around the inboard edge of the pan only. It would seem that Toyota recommends only a sealant and not a gasket. However, as stated, my gasket came with the sealant. Not 100% sure how to proceed. Leave the gasket out altogether or use both. I never used a gasket on my Caravan but others did with no leaking. I'm going to bet that you would recommend the sealant only. Toyota says mount pan three minutes after applying sealant -- no oil added for two hours... Found pic... ![]() Thanks!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-05-2017 at 09:29 PM. |
| Why Bosch auto parts doesn't list 2012 Yaris ? | DanMC | Third Gen Yaris General Discussion | 2 | 04-03-2013 04:05 PM |
| 07 YARIS Liftback FOR PARTS | benjomothians | Items for Sale by private party | 12 | 02-07-2012 01:53 AM |
