Old 12-08-2017, 10:59 AM   #1
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Originally Posted by DiCaprio View Post
Oh yeah the car needs to pass TÜV Inspection this Friday, so wish my luck haha.
My Yaris passed the inspection. They only had to change the rear brake pads.
(Every 1.3l french build car has rear discs instead of drums, as far as i'm concerned)
I'm just curious as to why the back brake pads worn out quicker than the front ones.
DiCaprio is offline   Reply With Quote
Old 12-08-2017, 08:04 PM   #2
dogsridewith
Drives: 2007 2-door hatchback
brake pads rust corrosion dirt front versus rear
Because the rear rotors are more contaminated/corroded? Like everything else at the rear of the car...from spray off the front tires. Notice how much thicker the crud layer on the backside of the rims is on the rear vs. the front? (Can see this on the outside of rims too.)
Old 12-09-2017, 12:54 PM   #3
Freedomage
Freedomage's Avatar
Drives: YARIS 2010 1NR-FE MMT
You are wrong I have a french build 1.3 yaris 2010 which doesnt have rear disks.
If everything seems under control, you're just not going fast enough.
Freedomage is offline   Reply With Quote
Old 12-11-2017, 09:24 AM   #4
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Is yours a base model then? I'm still trying to figure out why I have disks and others don't. Mine is a 2006 by the way.
Old 12-11-2017, 11:45 PM   #5
Freedomage
Freedomage's Avatar
Mid model.
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
